Twinscrewgt
Bad Smurf
So far i havent seen any shop post any IAT or mention them in mag articles.. This is important info.
If someone were to buy this kit from BBR, and later down the road want to add an intake manifold, heads, and cams, would they need to take their car to BBR for dyno tuning with the new parts, or would it be better to just buy a tuner kit and injectors, and have a shop tune the car, then alter their own tune when the other parts are added. Would a local shop be able to alter BBR's tune, or would you have an SCT with BBR's tune on it that was useless because the other shop had to make their own.
John@BBR, are the handheld tuners that y'all use, "locked", so that another shop couldn't alter you tunes? Thanks.
That is correct. Any reputable tuner will lock their tunes.
IAT's on the new stage 2 upgrade reached a whopping 77°
Prior with the H.O. kit the IAT's saw over 190°
HUGE DIFFERENCE!!!!!
77 degrees after the blower seems awful low?
has the sensor been moved to after the blower?
have you logged on the road after the car is hot and doing a couple wot blasts?
That's why I asked. 77 degree IAT is really low in a boosted application.
With the stage 2 intercooler, does ProCharger still use the MAFtercooler?
77 isn't bad depending on the ambient temp.
And yes the Maf is still in the IC
^ I'm hoping we find out the ambient temp. soon for that exact reason.
