46addict
13726548
As the title says, my last outings at the track have been disappointing. My car is Procharged with the 4.13" pulley and I'm seeing 8psi on the gauge. With a 2.2 60' time I trapped the same speeds as a stock 3v. Didn't matter if ambient temp was 75 degrees or 95 degrees. It dynoed at 429/380 and is tuned for 9.7psi. Target AFR is 11.6 and it dips below 12.0 from 3500rpm. I noticed by the time I see 8-9psi it's time to shift, so on average the engine sees maybe 5-6psi down the track.
Comparing my dyno graphs from when the car was full bolt on + cams versus now, the blower doesn't begin doing its thing until 4800rpm. Rev limiter is set to 6200 for the sake of stock internals. I bought this blower kit used from a member here, and from searching his threads, he had the same issue. His NA + nitrous times were faster than he was with the blower.
My intercooler piping has a provision for a wastegate, right next to the bypass valve. I ordered a gate with a 10lb spring and I want to try it with the 3.40" pulley. I believe it's the smallest pulley available for the 8 rib P1SC. With my IAT already at 140+ during a run (that's almost 2x ambient), this is probably a stupid idea without upgrading the IC or adding meth so that is going on the list. But I want to check other things first and see if anything broken/wrong can be fixed. I know I need traction but there's no sense in buying drag tires/wheels if my car has no power to put down.
My tuner had me datalog and he has the timing at 20 degrees and I saw 93% pump duty cycle. I did the BAP wiring upgrade using 10 gauge power& ground wires after seeing that. I haven't done a log afterward yet to compare. Is there anything else I can check before I go to my last ditch solution? How tight can I crank the belt without breaking something?
