Hello i'm currently in Iraq and having some work done on my car before I make it home. I'm upgrading suspension on the car and redoing the rear end as well. The 8.8 is currently coming out of the car to go and be rebuilt and have the axle-tubes welded up along with the carbon clutch disc upgrade as well. Here is my question. I'm going to be buying the BMR extreme anti sway system for the rear end and was wondering if anything from that kit gets welded to the rear end or if it is all just bolt on? If welding is not required would it help to be welded on? I'm already having them also weld on my drop brackets as well so I would just like to know before I send the rear end there and find out more work is needed. Also does this kit eliminate the regular rear sway bar? I would assume it does but would like to confirm this as well before having a sway bar relocation kit installed to help fit my new 15x10 racestars.
On a separate note, Does anyone have any experience with the new strange adjustable shocks and struts for the 05-09 mustangs? I want to buy some good adjustable shocks and struts and have always had good luck with strange but i know they are new so am just wondering. I've played guinea pig enough with other projects and don't feel like screwing around when I'm not even stateside.
Thanks for any and all help and advice
Larry
Larry
