Aaaarrrrggghhhhh missing issue
All I heard was wind. Sounds like it was breaking up, which is a lean condition, suspect injectors or tune. Leaning towards tune for sure if it has done it since the mods were put on.
Rokkit
Arkansas
k thats what i suspected all along that i need bigger injectors or a revised tune.. if u listen around 3 secs is where u can hear it popping really good and it continues... its just that after that the wind and exhaust drown it out... sorry its so loud.. and everytime i talk to the tuners they say the stock injectors should be fine for my mods and it also pops under part throttle in overdrive and while on cruise around 75
thump_rrr
Montreal Qc,
datalog and check fuel trims
Rokkit
Arkansas
mk what should i be looking for thump because ive datalogged and sent to bama and they said the car was doing exactly what they told it to do
AnotherS197GT
Serial Valve Dropper
Tampa, FL
Stock injectors are big enough for your mods. Do you have the old logs you took and sent in? If so, post them.
Tbone
London, On Canada
ok i ohm'd the coils and the injectors. coils seem to ohm out fine at .06 on the primary and around 5.64k to 5.88k on the secondary. the injectors i have to find out where they are supposed to be resistance wise but they all ohm'd out to 11.3-11.4.. At the moment trying to upload a video for you guys to view
Not the ohms I would be concerned about. My concern would be its not putting out enough of a spark under load.
Rokkit
Arkansas
sooooo i chunked my stockers when i purchased the accel any advice on other aftermarket coils seeing that ford wants over $600 for motorcraft brand or do i need to jus bite the bullet?
Rokkit
Arkansas
Datalogs
these are datalogs b4 spark plug and coil change
  • New 1 gear roll pull thru miss 3rd and 4th.pdf
  • new 3rd gear pull 55mph to miss.pdf
  • new 4th gear pull 70mph to miss.pdf
thump_rrr
Montreal Qc,
Guys on here who have 05-early 08 heads need to buy new COP's if they buy new FRPP heads with the 12mm plugs.
I'm sure there are a few old model sets kicking around here. The correct ones for you have black boots. The new ones have brown boots.
2004-early 2008 F-150/F-250/F-350 also use the same COP's
Wes06
well theres a lesson about scrapping old parts
I have no intention on going back to stock suspension, or stock cams, etc
yet i still have it all hidden away
Rokkit
Arkansas
i normally keep everything n the mrs always fusses how i have parts everywhere n i tell her u never know when u will need something again.. long story short i had a brain fart.. never happen again
What you have is breaking up from a lean condition, not a miss like you described which could be coil related. Imo you have a lean issue that is tune related, only does it wot?
Tbone
London, On Canada
Know anyone with a similar year mustang you could swap coils with? If there's a mustang club in your area may have some luck with that too.
Rokkit
Arkansas
ok found prob thank u guys for all of your help and input... it turned out to be a bad set of ford racing 0 degree plugs.. Went out on a limb and bought some autolite HT1's just to see what would happen and problem went away.. Pulls like never b4
thump_rrr
Montreal Qc,
Are they really bad or just too cold for your application?
Rokkit
Arkansas
im believing they fouled b4 i ever got a chance to put nitrous to them
