All I heard was wind. Sounds like it was breaking up, which is a lean condition, suspect injectors or tune. Leaning towards tune for sure if it has done it since the mods were put on.
datalog and check fuel trimsk thats what i suspected all along that i need bigger injectors or a revised tune.. if u listen around 3 secs is where u can hear it popping really good and it continues... its just that after that the wind and exhaust drown it out... sorry its so loud.. and everytime i talk to the tuners they say the stock injectors should be fine for my mods and it also pops under part throttle in overdrive and while on cruise around 75
ok i ohm'd the coils and the injectors. coils seem to ohm out fine at .06 on the primary and around 5.64k to 5.88k on the secondary. the injectors i have to find out where they are supposed to be resistance wise but they all ohm'd out to 11.3-11.4.. At the moment trying to upload a video for you guys to view
Guys on here who have 05-early 08 heads need to buy new COP's if they buy new FRPP heads with the 12mm plugs.sooooo i chunked my stockers when i purchased the accel any advice on other aftermarket coils seeing that ford wants over $600 for motorcraft brand or do i need to jus bite the bullet?
Are they really bad or just too cold for your application?ok found prob thank u guys for all of your help and input... it turned out to be a bad set of ford racing 0 degree plugs.. Went out on a limb and bought some autolite HT1's just to see what would happen and problem went away.. Pulls like never b4
