What size tires on front and rear? Enough difference in diameter could cause this.
My fronts are the M&H 185/55/17 and they measure 24.5 inches tall. Just so other will know.... I put the stock tires back on and the lights went out. Thanks for the replys. My car is an 08 if that helps anyone else. Really dont understand why this affects it but I only run them at the track so no big deal. If anyone knows how to solve this I am still interested. thanks again
I an running that same tire and it measure 25.8" tall
Remember that your ABS signal is based on wheel rpm. If you have a 24.5 inch tire on the car the rotation is off far enough from the rears that the computer recognizes an issue!
You could try cheating it a little by changing the revs per mile in the tune...more revs smaller tire. Will through off your speedo and may still cause abs faults, might worth a try though.
On the tire pressure. I run 45psi at the track, gives a little less roll out and less rolling resistance. I know guys that run 55psi in the fronts but I ain't that brave.
Lee
