gray1622
MY abs light and red brake light keeps coming on when I hit bump or under hard breaking then turns right off. I check brake fluid level, ABS rings and sensor for damage, connection on the sensor to the harness, and the harness around the axle. I recently change both front wheel bearing still have the same problem. It cant be fuse or relay right? If it was the light would just stay on. I am thinking I must have bare wire some where but for life of me I cant find it. Anyone have any suggestion?
