iceguyb14
Mustang Fanatic
Either way that's damn kool on the 2013s....... Enjoy the ride bro!
Lol thanks will do!
Our 2013 does the same thing even with the tune.
Here's what our testing showed.
Stock with 87 fuel 12.0
Stock with 93 fuel 12.6-12.75
Tuned with JLT CAI 12.5
Each time the dash gauge would read 13.9-14.0
I don't think that's too accurate, but maybe Ken can help with why it says this.
Logged from rear o2
I'd have to see a data log.
The dash may be showing commanded fuel and not the wideband info.
Sent from my Galaxy Nexus using Tapatalk
But commanded is the 12.0 right?
Ford also advertised twin piston rear calipers in the brembo gt lol
Well you can monitor real time AF through the wideband PID on the OBDII, which is really all this dash gauge is doing. So I can't see why it wouldn't
I can. lol. The same reason most oil pressure gauges are just an on/off gauge.
Sometimes the widebands don't read. When they aren't warmed up or for other reasons. Lets say in 3 years they go bad. The car will still run ok open loop. So if you were Ford, you could say....
Well commanded fuel should always match the actual A/F. And for 95% of the people buying it the difference isn't that important. If we make it the commanded fuel, then we won't get people thinking something is wrong when the wideband isn't reading.
Likely? No. But you never really know.
Oh wow, I'd just say that would be a poor decision to monitor commanded vs. actual on Ford's part.
CEL kicks on, P0174... system too lean?!?! But the damn dash reads 12.2
that could happen even if the wideband was being read. The system too lean doesn't mean that it's lean. It means that the long term trims are maxed out in that direction. It still could be getting the correct A/F
To the guys with the 2013, what is the refresh rate like on the cluster? Maybe it is just lagging behind.
UPDATE: I've tested it out a few times after talking to a few people. I've heard that even being at 95% the afr would be probably around 13.5-14 an only at 100% wot is when it would drop to around 12. Tested it out a few times pushing the pedal completely to the floor making sure its at 100% and almost every time it shows right at 12 on the gauge.
The refresh rate seems to be about half a second or so. Definitely not the cause when doing a pull that lasts several seconds.
Are you serious?
You mean to tell me this whole time youve been reporting the 14.0 A/F reading you werent even at WOT????? That could have been a little bit of important information to tell during this discussion. Just my .02 cents
Sweet baby Jesus.
