(4) 2005 Stock 17" wheels with 2 Kumho 255/50r-17 tires 30% tread (mounted) & 2 Nitto 555R 275/40R-17 Drag Radials 90% tread (mounted) & one 275/40R18 Sumitomo Tire with 90% tread (not mounted) ------------------------------------------------------------ $200.00
New Ram 2005 11” Clutch kit with 26 spline disk Ram88952T ---------------------------------------------------------------------------- $50.00
New 2005 Stock Mustang GT Flywheel part 1R3Z6375EA -------------------------------------------------------------------------------$50.00
2005-2008 Ford Mustang GT MotoBlue RS Series Axle-Back Mufflers ------------------------------------------------------------------$50.00
(3) used gates belts for Saleen Blown 2005 & up Mustang GT 90% life K061075,K061073,K0611080 -----------------------------$10.00
(1) new Goodyear Belt for Saleen Blown 2005 & up Mustang GT 6DK2770 -------------------------------------------------------------$5.00
Harrop short throw shifter 2004-2006 GTO or S197 Mustang with D&D T-56 ---(cost new $200)------------------------------------$25.00
Stock 2004-2006 GTO Shifter or S197 Mustang with D&D T-56 --------------------------------------------------------------------------$20.00
Stock Drivers Side A Pillar in Black-------------------------------------------------------------------------------------------------------------$5.00
Stock 2005 & up 5 Speed with stock 5 speed shifter, crossmember, & drive shaft (3rd gear syncros bad) ----------------------------$50.00
Stock Air box & filter-------------------------------------------------------------------------------------------------------------------------------$15.00
Stock manifold with charge motion plates-------------------------------------------------------------------------------------------------------$50.00
Stock 2005 Mustang GT fuel Injectors ----------------------------------------------------------------------------------------------------------$25.00
Stock Exhaust manifold & gaskets --------------------------------------------------------------------------------------------------------------$15.00
Metco Motorsports 2 piece Drive Shaft Safety Loop 2005 & up Mustang GT -----------------------------------------------------------$50.00
2 Bassani Cat Delete tubes------------------------------------------------------------------------------------------------------------------------$10.00
Stock 2005 & up Mustang GT Lower Control Arms------------------------------------------------------------------------------------------$10.00
Stock water cross over tube -------------------------------------------------------------------------------------------$20.00
3.0 Blower Pulley for S197 Saleen Supercharger can be with 6 & 8 rib belt--------------------------------------------------------------$50.00
2005 Mustang GT Stock fuel Pump --------------------------------------------------------------------------------------------------------------$50.00
15 USED Autolight HT0 Sparkplugs -------------------------------------------- ---------------------------------------------------------------$15.00
*Also, I don't use paypal so I would need a money order or cashiers check*
