RocketcarX
95% of my weight is fuel
ALright, lets start at the beginning, lol. My Cervini hood, the shipping company AM choose to ship the hood held it at a distribution hub for over two weeks because they were waiting till they had a truck already going our way to deliver it to my body shop, completely held up my build and cost me rental car days. AM recommended their wiper arm mounted squirters with the hood as if it did not already come with a squirter system from Cervini, the AM squirter kit used white plastic bits to hold the rubber line which stood out too much and were held on with double sided tape the eventually let go. Obviously I am now running the squirters that came with the hood. I also ordered the recommended AM hood strut kit, the lower brackets were drilled wrong and the struts while barely able to hold up the fiberglass hood, causes it to over arch when closed and ruined the body likes, at which point I removed them.
Plug in sequential tail lights, failed to seal to my OEM tail light housing allowing moisture to ruin the tail light reflective material inside the lens. The module started blinking erratically and required replacement along with the tail light I still need to replace.
Well I suppose I should have learned to stay away from their house stuff because the SR Performance SS clutch line I just received looks like it's already corroding. I almost scared to use this thing in my car with the gouges and corrosion in the finish.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
I can post pics of the other things I mentioned if anyone would like.
These will probably be my last AM orders. I also purchased my Exedy flywheel and Mach 500 clutch kit as well as the Ford roller pilot bearing, from you guys due to the price point and the forum discount, and they did actually get here today, a day early, so that was def cool, but really I am getting tired of having some disappointment with almost every order :/
