Any reason to change the dif?
AndrewG27
Deltona, FL
Hey guys, I'm planning on changing out to 3.73 or steeper gear in place of my 3.31s. Just wondering if there is a reason to change out our factory dif?
I haven't seen on here anyone telling how much better the torsen is over the stock one, but i have been looking at it as an option.
Right now I'm just running with street radials and bolt ons. In the future I may run nitrous or low boost but probably never go over 600whp or so.
If the factory dif can hold that kind of power and if upgrading doesn't show any real noticeable difference in hookup then I'll just leave it be, but I didn't want to have to tear apart the rear again to change it in the future.
Thanks guys.
Rob72
No Japanese Mustang Here
Baltimore, Marxland
Carbon fiber clutches would be a nice upgrade while you're in there.
BAKnBLK2010
Harley Davidson FLHTCI
Sandy Hook Kentucky
The stock diff will be fine but the clutches will wear out eventually. You could upgrade to the Detroit Tru Trac and never have to worry about replacing clutches. Any diff is subject to break at some point with a sticky tire so it's just gonna be up to you to decide if upgrading at this point is worth it or not.
darkstar november
magical turning mustang
ft lauderdale fl
the torsen is killer. its a whole different car with it, we just did one in a customers 650whp gt500 and the difference is unbelievable.
as soon as i have the cash i will be buying one
BAKnBLK2010
Sandy Hook Kentucky
Lethal killed the torsen in their Boss after some drifting and a couple of dragstrip outings. Seems like it should have held up better than what it did.
darkstar november
ft lauderdale fl
the drifting they did was not the same kind of punishment a normal person would give it, they had a pro drifter driving the balls off the car, your average person wont kill a torsen that fast
erat
What does it accomplish other than being stronger?
Tron
Ft. Bragg, NC
So you put an aftermarket diff in to drive it like a normal person? :rollseyes:
BruceH
BBB Big Bore Boss 322
I didn't notice much difference going to the Eaton trutrac. I did it because I needed clutches and didn't want to mess with it again.
OP: The stock differential is pretty stout, no need to change it if you aren't abusing it.
ford20
White Plains,NY
So the Tru-Trac really didn't help with traction that much?
fdjizm
Drag Queen
NY/NJ
Yes big problem, it's called one wheel peel and it will happen eventually.
Go for a truetrac and never open that pumpkin again!
Also those spider gears, but maybe that was just me and my racing...
BruceH
If power is going to both wheels it doesn't matter how it's getting there if you are going in a straight line. I did the trutrac because I was swapping gears and needed clutches. I figured why not put a trutrac in at the same time and never deal with clutches again. I would think the torque biasing would help on a road course but I've never done a road course as I think it would be the crack cocaine of racing and end up costing me my house, family, etc.
RedDragon777
Mercedes, TX
I am actually looking into a Torsen when i swap my gears. Since i do almost no drag racing what so ever i am not worried about killing the Torsen. If i did drag race more than road race then i would go for the tru-trac.
BruceH
I looked at the torsen too (named after the inventor of the torque biased differential by the way). It was a few hundred more than the tru-trac and like you mentioned not as strong.
wbt
As mentioned in the other thread, I firmly believe your issue was caused by not running a diff cover with bearing cap support. You experienced deflection causing the issue seen in the pic. The stock diff is plenty strong.
fdjizm
Drag Queen
NY/NJ
Yea I gotcha, just saying I loves me some trutrac now lol
