Well I've read through a lot of the threads about broken oil pump gears, and I haven't been able to pick up on whether any cars (or trucks) running the ATI super dampers have broken any stock oil pump gears. I've read about Innovator's dampers and broken gears, but don't recall ATI dampers and a set of broken gears.
I've been tossing around the idea of adding an ATI damper, since Roush charging my F150. I've also considered the billet oil pump gears, but would like to avoid that expense if possible, hence the question.
If you know, point me to the thread or furnish the info here, if you don't mind.
I'm really not looking for opinions here, I'm specifically asking about ati dampers and stock gears, and perhaps with pd blowers would be even more helpful
Mostly I would be interested in coyote motors, however I understand it's a ford modular problem in general
thanks in advance
thanks in advance
