pqtiii
The back of the car started swaying when I shifted gears going down the highway. I check the oil and it was solid black. I assume the clutches are totally gone after about 200 passes at the track. I noticed that one of my wheels would stop spinning during a burn out towards the end.
Does the clutch particles in the oil cause the bearing to go bad. I need to change the clutch pack, so should I replace all of the bearings too?
Thanks
pt
Thanks
pt
