Such intolerance from the gear Nazis here, as usual. The NA Coyotes that are quicker than my car are much lighter (lots of weight reduction) and/or have more mods/power. My car is 3800 lbs going down the track and has only a couple of mods. 100% stock engine down to the stock airbox & paper air filter plus 100% stock suspension.
Again, the key to a successful build is in choosing parts that work in harmony together in the same powerband. There are certainly some combinations that work better with less gear, just as some combinations work better with more gear. Don't let anyone tell you that one gear ratio is the only "right" ratio for all combinations.
It's not intolerance, it's having the data to backup the recommendation. We have been down this road. More gear doesn't = better ET N/A. The past several years I have personally witnessed this fallacy. I will pose the question once more, why do the quickest/fastest stock long block Coyote's run less gear?
Your combo is far from optimal. You want to talk about weight.....how about DA?
You need to have a serious look at the transmission ratios compared to tire size and optimal RPM. Once you understand that then you will know why more gear doesn't = better ET's with the auto.
I have a proven, repeatable combo to get these cars into the 10's N/A and high rear gear ratios isn't one of them.
Insightful threads:
http://www.s197forum.com/forum/showthread.php?t=107585
http://www.s197forum.com/forum/showthread.php?t=107063
