DPE
Swapping from Ford P springs to BMR Handling springs today (the stiffer ones of BMR's). I have 2011+ Konis and the 2011+ Steeda camber plates.
Steeda camber plates come apart fairly easily if you don't let tension off the spring fairly gently and easily, but it wasn't a notable problem with the FRPP springs. But the BMR springs are shaped a bit differently at the top, and load up one side of the top mount a bunch before the other and cause the mount to separate on one side and end up all cockeyed. We've tried multiple times, decompressing the spring differently, and even installed them on the car and jacked the strut assembly up to see if the upper mount would compress back together and it simply won't.
Is this a known thing with the BMR springs not working with Steeda plates? Or are my springs possibly made wrong? Anyone have BMR Handling springs with some other camber plate that works fine with them? Never heard of this particular problem and now the car is going to be sitting for a couple days (unless I just put it all back together like it was before). Which I already put the P spring back on with the Steeda plate and the assembly went back together just fine; that to say we didn't screw anything up in the process I don't believe.
