Good vids!
Can't say I have seen anyone mount the pivot with the spacer on the outboard side like you did.
And yes, those bolts are a PITA. Did you get the shorter ones I sent you?
he
Thanks for the installation videos! I noticed that you are calling the RC position as the 3rd hole, but I was under the impression that BMR numbers them from top to bottom which would mean your is in the 4th hole? Am I misunderstanding? I'm waiting on the correct bolts/parts to install mine.
Thanks!
I actually have no idea how BMR numbers them, either I didn't see it or didn't remember them referring to them that way.
When you're under the car and cant even see the top holes from the diff side, it made more sense for in a video showing it to say 3rd hole.
No problem just trying to gather all of the info I can from those who have already installed. How much clearance between the brace and the tailpipe on the driver side? I currently run the BMR panhard bar and brace and I had to add a couple of washers under the brace to keep it from contacting my tail pipe on the drivers side.
Nice! Good work sir. And yeah, when I personally do things they get 2 day.....when the shop does them, good ole ground. Ha! Sorry about that.
Maybe mounting the camera on the front side, from the opposing angle would be good. It's different, but could still show some nice data.
On that note, I suspect many people are not as concerned about the lateral deflection, as they are the ability to dial in their RC. Throw that pivot high, then at bottom and give us your thoughts. I've been running all kinds of different combos on ours, and I gotta say....with our heavy bar out back and the bottom RC position...it's a fun ride with 650 rwhp.
