FR500GT
shaving the hubs makes the offset numerically higher. but if you shave the to 30...on an 11" rim....thatll stick out ALOT. That and i dont know if anyone has even fit an 11" rim.
have you searched around here for wheel threads? Theres alot of great info and choices that are brought up. from hella flush to tucked.
Last point - if you want the look then I certainley understand wanting such a wide back tire, but you do realize its just gonna slow you down right? there are guys over 500rwhp on here (myself included) that arent running tires that wide.
- If you have a 9.5" wheel with a 30mm offset and widen the rear wheels to 11", that will only add 1.5" to the inside of the wheel...so offset is not affected. Plenty of people run 11"s in the rear on the s197 (it just takes the proper offset).
- Most of my time on here is searching, and I have deallt with soo many offsets its rediculous haha.
- I completely agree on slowing you down, I would never run a 325 tire. I was going to be putting on 305 R888's which is plenty of meat for an 11" wheel without it being an overkill.
