I'll ask the obvious regarding a tune. Did you have it retuned?
You know, thats what I'm thinking. I had emailed Jon Lund a few days ago prior to installing the intake requesting a retune. He stated my previous tune was already calibrated for the boss intake.
That would be unusual IMO. If your stock intake and the Boss intake run on the same tune that would be a waste of money IMO.
Surely it requires a change in the tune between the 2 intakes. Mine did going from the OEM to FRPP intake.
Look at the possible causes I listed
I would suggest the obvious again and go back over the install and make sure all connections are secure AND correct in orientation. Other than proper install and the possiblity of needing a tune, this mod should be as easy as putting gas in the car.
I've heard, that with the factory widebands and commanded A/F ratios there was some flexibility in the tuning. When I went from the boss intake back to stock my a/f did not fluctuate. Hopefully one of the vendors will answer this for us.
Sorry, i don't care what he says. I would still do some datalogging and/or throw it on a dyno for good measure.
You sure you put the MAF sensor in right? :x
Baknblk has spoken bro.
Well appearently shining a flashlight on it and calling it dirty names fixes the issue.
