Bought a 2006 and back timing chain rattles for 20 seconds then quits, Tensioner?
Ed Brown
Was hoping rear tensioner could be changed to get by a while. Car has 10w 30 oil in it, might try 5w or like a 0w oil. Previous owner put in 10w since has over 200,000 miles.
DieHarder
Changing out anything on the timing chains (especially rear) for a V6 is a wickedly tough job.
There's a four-part YouTube series by Ford Tech Makuloco which is about 3 hours in total that does a good job explaining and showing everything involved. Given yours has over 200K why don't you go for a low mileage used, rebuild or swap?
Ed Brown
I was thinking the hydraulic tensioner is wore out, once it get oiled its quit as can be, it not hard to get to rear back of head. Just bought, need to drive, but will look for a low mile engine and probably change the cartriges out on them while out.
O_M3G_A
For any engine with high miles I would stick with the recommended viscosity and with a bottle of STP High Mileage Oil Treatment, UNLESS you live in cold weather, then I would drop to 0w(0w-30). I own a 2011 Elantra with 287K miles, it developed the famous piston slap at 140K on 3 cylinder and its still running using the recommended oil viscosity and a bottle of STP , I live In Cali, and last year I took it to Texas..
Increasing the oil viscosity can do more harm than good, your oil pressure will rise BUT oil delivery through out the engine will take a hit, especially to places further away from the oil pump. There is NO NEED to replace the engine just because of the mileage UNLESS there is something severe with it, a simple timing chain rattle caused by a worn tensioner or stretched chain is nothing to be concerned about, since they can be replaced and solve the issue. My 2010 has 163K miles, and aside from a transmission issue, the engine is healthy, I checked the rear rod bearings(furthest away from the oil pump) and they looked great, almost new, inspected the cylinders using an inspection camera, looks good very little carbon deposit and cylinder cross hatches are still visible on all 6... not to mention great compression too..
In my opinion pull the engine out and replace both timing chain cassettes.. or a rebuild, new bearings, oil pump, rings, etc. if you're still worried.
IMO, it is decision time, repair or replace engine. The only sure thing at this time is the engine is coming out.
Iceman62
Bullitt 6005
NE
^^^This^^^
If that thing lets loose - you'll be doing 2nd option anyway.
Gabe
Whippled Coyote
I had an '01 Ranger with the 4.0 SOHC in it, had the engine pulled and all the timing chains and cassettes replaced at about 60-70k miles, the start-up noise never went away, it got better but was still there even after all the work, which was done by a good engine tech at the Ford dealership I used to work at.
The guy had the engine out and on a stand in less than an hour, lol.
Honestly, at 200k, I would drive it as is while looking for a late-model engine replacement with low miles.
tjm73
of Omicron Persei 8
Rush, NY
This is a common issue with the 4.0 SOHC engines. The fix is well documented online.
tjm73
of Omicron Persei 8
Rush, NY
:lol:1 hr to pull engine=experience.
Truth.
In the mid-late 90's there was a young guy that worked for my Dad in his dealership for a number of years that would drive an Econoline van into his work space at 8am, pull the bad engine, install the replacement engine and back it out 100% done before 5 pm at the end of his work day. He did it several times. And he took two breaks and an hour lunch. Now if you ever worked on, or even thought about working on, an Econoline van you know this is no small feat.
Biggest thing with vans is pulling off the front end/grille! Been there done that, was a dealer tech for 15 years.
Aerofinz
Mustang's Backyard
[QUOTE="Gabe": Honestly, at 200k, I would drive it as is while looking for a late-model engine replacement with low miles.[/QUOTE]
Best answer. They are relatively cheap.
Best answer. They are relatively cheap.[/QUOTE]
I got $500 for my v6 with 100k on the clock, that was 4 years ago. Guy told me he had a difficult time finding a good used 4.0.
Aerofinz
Mustang's Backyard
To me that is an example of "relatively cheap" (what do you buy for $500 anymore?). It looks like your right, 2-3 times that currently on Ebay. More reason to just drive it!
Bullitt2954
Southwest MO
Truth.
‘70s/‘80s Dodge Tradesman vans. I don’t know why, but my Dad loved those POS’s.
Bullitt2954
Southwest MO
If I were to guess, they were tough as nails and could swallow a lot of stuff.
We did a v8-swap on a s6/manual once. It blew ass trying to find and fit small, fiddly-ass parts like linkages and mounts, harnesses and the like.
This was back in the days when NOBODY made any kind of “kits”, for ANYTHING.
nfrizell
These leak down when sitting because the gaskets blow out.
Sent from my SM-G965U using Tapatalk
I was thinking the hydraulic tensioner is wore out, once it get oiled its quit as can be, it not hard to get to rear back of head. Just bought, need to drive, but will look for a low mile engine and probably change the cartridges out on them while out.
It's becoming increasingly difficult to find low mileage 4.0 V6 engines since their production ended 11 years ago so I suggest you remove your existing engine and refresh it with new timing chains/guides/tensioners, new rod/main bearings, new piston rings, new oil pump, and new gaskets/seals. If there's a ridge at the top of each cylinder, you'll need to have them rehoned. Do it once, do it right, and you'll have an engine that'll last at least another 100k miles. You could also use the opportunity while the engine's out to bolt on a pair of headers and underdrive pulleys to add some performance.
If you're planning to keep the car for at least five years, it might be worth the expense. Otherwise just do the minimum necessary to solve the immediate problem (new rear timing chain, tensioners, and chain guides) and leave it at that. You could then start saving pennies for a future Coyote swap if you change your mind.
