madrussian
T-101
Any tips or suggestions? Anyone done that before? Is there a DIY or step by step?? Please help as I will be changing it out end of this week or next Monday.
Its pretty easy---there are four bolts under the dash above the brake pedal and one to the brake pedal arm. If you are replacing with another stock one it should be pretty straight forward. When you bleed the brakes, start with the passenger rear, then driver rear, pass front, then driver front.
are you putting a stock replacement?
Stock, I don't think I have a need of aftermarket one on the street
YES..After you remove the master cylinder.So after I take 4 bolts off and disconnect it from the pedal, what's the next step, it has to come out from the engine bay right? What do I do with brake lines?
oh man sounds like I will spend some time on that, shop qoted me over $400 for it, my buddy sad its a fairly easy job....Haynes manual at any parts store. Also, you will need to remove the master cylinder from booster before or after removing booster. And, bench bleed the master cylider before installing all parts. If this sound to much you might just spend the $$ and have a shop do it.
AND....MAKE SURE YOU ALIGHN THE MASTER CYLINDER TO BOOSTER SHAFT INORDER TO NOT DAMAGE YOUR MASTER CYLINDER.
You can get a M/C booster for under $200. Labor should be no more than 1.5 hr's. That would put it in the $400 range with tax. If they qouted you $400 just for labor laugh and comment your not paying for tech training bill and walk out. Any good tech should be able to do it in an hr. I did and I'm not a tech.oh man sounds like I will spend some time on that, shop qoted me over $400 for it, my buddy sad its a fairly easy job....
But techs are like doctors, lawyers and the such. A lot of bad ones and few good ones. When you find a good one stay with'em.
$70...junk yard? There are plenty s197's parts around now, forgot about that. If you have worked on cars or other mechanical stuff, with the Haynes manual and taking your time you should be able to complete no problem. It aint rocket science justa attention to detail.$400 job completed. I found brake booster for $70, so I will go ahead and try to do it myself
Where can I get Haynes manual?$70...junk yard? There are plenty s197's parts around now, forgot about that. If you have worked on cars or other mechanical stuff, with the Haynes manual and taking your time you should be able to complete no problem. It aint rocket science justa attention to detail.
Good Luck.
