K
killermach1
Guest
Does anyone have these cams, or know someone who does? I am interested in them and would like opinions on them.
How does forced induction contribute to valve float. I understand how a higher lift can.
Thanks for the link, Very interesting and educational. Do you know the point where the 05+ Mustang GT's start having issues with there valves spring rates?
The Comp Cams 26113-24 spring kit, Manley Nextek 221-429-24, or the PAC 1233 will work fine. Changing springs in these engines is a daunting task for a novice. There is a special tool needed to compress the springs and you will have to have an air compressor and screw in fitting that goes into the spark plug hole to hold the valves closed while changing the springs. Can it be done in a day? Yes. Again...not easy but can be done. I really don't think you will have a problem with the stock springs for quite some time with that blower at 10psi. If you plan to push towards 20 psi or planning on seriously racing the car competitively then you might think about changing springs.Okay, so here's the million dollar question:
What strength spring do we need in our supercharged 05+ mustangs and how difficult is it to replace them? Can it be done in a day or does it require completely removing and breaking down the heads. In which case, it's probably smarter to get used ones and have them reworked before building your engine?
I'm planning on getting a Saleen put in with about 10PSI, so what springs would I need to avoid valve float?
-Darth
First....I will not attempt to judge Al's statements in a magazine article or question his motives in making such a statement. I do not believe he has to resort to such tactics to sell his designs. Al is exceptionally good at his business and has proven that fact more than enough times. He is one of the truly great minds in the business. Having said that (if it sounds like a disclaimer...it is!).........LSlayer said:Al Papitto of Boss 330 Racing states that the Cam Phasers on the 3V heads are too weak to deal with stiffer than stock springs. He says that the springs on the cam phasers themselves aren't strong enough to properly hold the phasers in position when higher rate valvesprings are used. In certain cases the phasers will rock back and forth producing a lot of noise and even cracking on occasion.
Any merit in this statement, or is this someone trying to sell aftermarket cam phasers?
Could somebody give the thread-starter information on these cams incase he is NOT blown?
Asked and answered above. But here it is again.Thanks, I was wondering if someone would ever talk to my original question. I am about 85% sold on the idea of getting these cams, I will likely be N/A for at least the forseeable future 2-4 years.
Another thing you need to keep in mind about valve springs even in N/A applications. While these cams might be mild enough for a stock spring they will still put increased stress on the stock spring. Add to that the added stress of you putting your foot into the firewall considerably more now that you have some newfound power and you accelerate the spring fatigue. I am of a mindset that anytime you put added stress on the valvetrain (whether by camshafts, boost, or both) you MUST upgrade the valvesprings. Cheap insurance.
What would be the point of buying these cams? Even for a N/A car there will be little or no gain and I will vote for no gain at all. What motivation would you even have to put in these "no springs" cams on your car.
These cams are so mild theywon't even sound "cammed up" if that is what you are after.
The stock cams will work fine and save you $2000 or more of getting this all done. That is half the price of a supercharger for maybe 0-5 HP gain?
Seems like a really bad idea to me.
