BruceH
BBB Big Bore Boss 322
But im doing zex wet kit.
Then why did you say you were going for 350 na?
What kind of times did you run with that setup?
I'm almost maxed out on N/A with mine. Lots of fun but I tend to agree with saving the money for a blower. Getting a dyno tune is more important than a lot of parts, seems like that would help a lot of guys here that aren't seeing the results they expected from mods
Sent from my XT1080 using Tapatalk
12.1 sounds pretty quick to me, especially for a car that isn't prepped for drag racing.
I agree Bruce, just cause shop has a dyno doesn't mean squat. Datalogging doesn't mean beans either unless you got someone behind the screen that knows what they're looking at
you can get ported/polished heads fully assembled with beefier springs for 2k. cams for $700. $2700 and you could see mid to mid high 300's I bet. cmpd's would be a good idea for either setup. But boosting the car you gotta worry about the engines strength, add in extra for gauges, around here getting a dyno tune for boosted applications is $150 more, it all starts to add up. I'm not versed in adding more fuel to a cam like hotrods with just basic bolt ons however. If it yeilds good results I'd be all for it but I don't think the car is going to be running out of fuel with those mods. Hell you can run ported/polished heads, a big cam, and an intake manifold on the stock fuel system from what I've seen
If you're doing heads and cams, is there a good way to raise the compression? Without doing work to the bottom end. Or would it just be best to replace the pistons?
Can you take 1mm off the head?
Do the stage 2 heads lower the compression ratio?
