rad_rob
- Joined
- Jan 25, 2008
- Posts
- 230
- Reaction score
- 0
Well, as the title says, Im trying to get a feel if there would even be any interest in buying this rear end. I know there are a lot of guys out there putting down some serious power that would actually need it. Some of you may remember me posting about it not to long ago when I first got it.
Anyways, it is a Currie 9" rear end. 31 spline forged alloy axles, with ABS tone rings installed so you can still run stock brakes, or any aftermarket brakes designed to bolt to the stock rear. Housing is a brand new (not good used like most 9" rears). 3rd member is a Nodular Iron Race case, with Nodular Iron big bearing pinion support, which are rated at around 1000hp. It comes with a Tru Trac limited slip differential, and 3.89 Motive gears. The rear end has maybe about 10-15k miles on it, but will have all new bearings installed before sale.
I also have an Inland Empire Driveline aluminum 1-piece shaft designed to work in conjuntion with this rear end.
I also have a brand new unused Currie adjustable upper control arm that I would highly suggest using with this rear end as well.
As I said, I am just trying to gauge interest to see if anyone would seriously be interested, and if so, I would have no problem selling.
I am looking to get about $2500 obo for this whole setup. If interested, I will snap some shots when I get home, as well as post the ones I have from when I first picked it up. Thanks!!
