Bullitt w/ Paxton tuned!
Jeffs FRC
Bartlett IL
Not sure if this belongs here or not...mods feel free to move.:thumb:
So I finally got the car dyno tuned yesterday and all I can say is wow! Ive had the Paxton on for a couple weeks with the base tune downloaded waiting for a trip to my tuner. The tuner is Bob Kurgan of Kurgan Motorsports.
Mods
Paxton 2200SL HO kit w/ 3.33 pulley
60lb injectors
KB bap
Pypes longtubes/OR-X
CMDP's
Bassani race A/B's
FRPP plugs gapped .030"
IAT relocated to TB elbow
Std. numbers
Sae numbers
KrisR
Wyoming, MN
Great numbers! I'm guessing around 12lbs of boost with that pulley and longtubes?
Hope your shortblock holds up for awhile (it's still original, right)?
EDIT: nevermind on the boost guess...didn't see the boost curve graph. :)
that's a nice amount of power for 12psi
TonyN
Ford Junkie
Virginia Beach, VA
Wow, them are some damn good numbers. But scary high for a stock short block. I hope mine aren't that high or there will be some de-tuning going on...lol. Maybe I will run around 11.5 A/F ratio and 15* of timing??? We will see.
I just want 450-475ish. The 3.33 is the standard HO pulley correct (10psi@6000 rpm)? Hell, we have the same mods except I have cams. Uh Oh... :shock:
Anyways, congrats and good luck!
:thumb:
Jeffs FRC
Bartlett IL
You guessed right! The SB is stock...
Yeah, the tuner and I agreed that it is a bit much so before I left he pulled 1.5* of timing to be on the safer side. This run was 17* with it seeing 18* the last couple hundred rpm.
Jeffs FRC
Bartlett IL
Wow, them are some damn good numbers. But scary high for a stock short block. I hope mine aren't that high or there will be some de-tuning going on...lol. Maybe I will run around 11.5 A/F ratio??? We will see.
:thumb:
Standard pulley is 3.48. I swapped it out to the 3.33 just to make sure I met my goal. Looks like I was at 10psi at 6000rpm with the 3.33.
TonyN
Ford Junkie
Virginia Beach, VA
Ahhhh gotcha! Good to know, thanks.
I'll assume the standard 3.48 pulley will be around 8psi @6000 and a peak of 10psi after that.
