I have a Canton Oil Pan for the Modular engine. It was drilled for my twin turbos and has a plug installed on each side at the front, from when I went to water only Comp turbos. Other then the plugs it is in very good condition. The plugs don't effect anything but when I went back to oil cooled turbos I didn't want to try and remove the plugs and re-install drain lines so I bought a new pan and put new openings in it. I am asking $150 plus shipping for this pan.
In this pic you can see one plug on the far side of the pan in the front.
Very clean
Very clean
