ChiDiddy
Over the week I removed my turbo kit to install a pro charger kit. After uploading the tune, i attempted to start the car, but nothing. Full power is available, car clicks, but motor will not even attempt to turn over. I checked all grounds, power electrical cables, etc and nothing.
The only thing i disconnected while switching over the power adders were o2 sensors, maf sensor, and horn. Other than that, i cannot imagine what could have gone wrong.
NOTES: starter clicks, fuel pump powers ons, not PATS issue, no codes.
One thing i noticed was when i tried to start the car for the first time, s saw and smelled a little smoke come out from the area opposite of the battery location, on the driver side. But after the first attempt to start the motor, i never saw the smoke again. I don't know what could be in that area that could have fried up to cause the slight smoke.
When installed the pro charger, i had to remove the current harmonic balancer because the piggy back balancer that comes with the pro charger would only fit an ATI balanacer or the stock balancer, therefore i went back to the stock balancer.
Any help or inout is much appreciated.
I have searched and gone down the checklist provided by 94tbird and did everything exempt these because i don't know what it means, know how to do it.
Will the rotating assembly turn freely?
NO – engine is jammed or seized
YES – continue
Does the starter motor turn when power is applied and load removed?
NO – bad starter
YES – have starter bench tested.
YES – continue
NO – bad starter
