fordracing
12.84@108 1.89 60' N/A
I called Centerforce, Fidanza, RPS today. Centerforce recommended a DF clutch for my car, with the whipple install. After all the DF clutches I've read about getting hosed I don’t think this is an option. I asked him about the DFX and he said it would be away too much clutch for the car. Up next Fidanza recommended their twin disc then told me to call A vendor that has them. I called the vendor and they told me because they are still new to the clutch market to stay away from them. They recommend either a Spec 3+ or a Ram HD.
I then called RPS and they told me they don’t make anything right now but in a couple weeks would be testing a twin disc unit... Talked to them for about 40 minutes, Very knowledgeable, explained all the choices out there and how their clutch is better. But of course there is a catch here too; this clutch is going to go for around 2000.00
After talking to him a lot of the clutch problems out there make more sense to me now though. Basically clutch disc diameter (mass) has allot of effect on shifting and transmission wear.
Something that stood out to me was he said think about shifting at 6000 rpm. when you push the clutch in the RPM have to drop about 1000 RPM before you can go from 1st to 2nd. The syncro's are designed to do this they introduce drag. if you have a heaver clutch disc it takes more time for the RPM to drop and to the syncro's has to do more work to get it to drop that amount. I know that Rench has had allot of luck with RPS clutches and this could be exactly why. he has a 10.5" compared to the 11" and their disc also has less mass then most other 10.5" discs
So anyway; all this just has me more confused and now I have NO idea which clutch to buy.
Done venting...
Done venting...
