I converted and went with a 10% overdrive pulley at the same time and I'm seeing 15lbs at 6k rpm
What size pulley on the headunit?
I'm at stock crank with 3.33" pulley @ 10 psi.
I made 22psi with a 3.15 pulley and 10% overdrive. Around 23-24 with a 3.0
And you're making 485hp on 15psi or is that an old dyno run?
Boost is based on intake/exhaust restrictions (cylinder head flow), and bore size.
More static compression can add power to a boosted engine without adding boost, but adding boost without changing static compression will increase effective compression.
Short answer is, boost is not dependent on static compression.
You might be running into belt slip issues on a <3" pulley. Are you running a stock crank pulley?
I never ran an o-ring in mine.So you know the vband clamp & flange that comes with the Tial bov? Is there supposed to be an oring in between the BOV and the flange???
Looks good! I run a vortech mondo.
