07gts197
I was born in '93 lol
I think the vibrations are slightly different, and refining/changing the NVH for one reason or another was what drove the change.Re: distributor in the new trucks, I was making fun of them changing to a firing order that helped limit cross firing in a distributor app - when there's no way that's why they'd do it today. It's a mystery!
Oh fuk!!! I am old. I graduated HS in '91.
Old??? Sheesh.Well shit, I graduated in '88!
I envy all you you born before my time. My generation is pretty pathetic tbh and I feel like we're going to be the downfall of our nation.Oh fuk!!! I am old. I graduated HS in '91.
Has anyone noticed a coyote powered fox body sounds better than the newer Mustangs? Might be due to muffler location, not in the rear like newer models.
Getting the 'right' exhaust sound is close to top priority for some people, and there's enough of them to support an entire subset of the aftermarket performance parts business.Exhaust sound? Really? Coyote vs. 3V? I couldn't care less if the Coyote was dead silent-it's a Coyote!
If you look at the LS its firing order is similar to the HO or 4.6 firing order. 13726548 and LS is 18726543.
Back in the day the power difference was in the camshaft. The big reason for different firing order was to have a distinct sound for the mustang only.
Would be interesting if there was someone who built a coyote in stock form to run the old HO order and see if there is in fact a power increase.
Ford and GM identify the particular cylinder differently.
Ford is 1-2-3-4 up the passenger side and 5-6-7-8 up the driver side front to back. GM is 1-3-5-7 up the passenger side and 2-4-6-8 up the driver side front to back.
Putting them in the same cylinder location makes the FO's this...
HO 1-3-7-2-6-5-4-8
LS 1-8-4-5-7-3-6-2
Wrong. 351W had this "HO" firing order back in 1969. 351C/351M/400M Also used it. Got ZERO to do with having a particular sound. I have nothing to back it up but read that Ford found the "HO" firing order ran smoother and made more power than the other 289/302 firing order. I also read that the HO firing order was better for EFI, but they used the non-HO firing order with EFI too so I don't buy that idea.
Did you read this thread? When the '15 5.0 trucks came out Ford changed the power rating and they went to the HO firing order. Mere coincidence? I coudln't say for sure, but I doubt it was done on a whim or for a sound. Was either for power or NVH is my guess.
