Coyote with a carb and a turbo...why? Why not.
Discussion in 'Hardcore Tech=*MOTOR SWAPS*' started by spyder7724, Aug 16, 2015.
  1. spyder7724
    spyder7724 Senior Member
    845
    Apr 21, 2007
    Maryland
    It's an UCA relocation mount from Baseline Suspensions. It raises the rear upper control arm mount to adjust instant center and anti-squat. Also has track locator built in which Centers the rear housing. Fox body fords and Gbody GM cars have triangulated 4-link suspension. Once we replace all the bushings with spherical rod ends there is nothing to stop the housing from moving side to side during launch or cornering. You see the foxbody twist or Gbody shuffle .... It's poor control of the suspension. My car also has an ARB but it's not necessary with a good locating device unless really going after it hard...I plan on that.
    S197 cars have an panhard bar or sometimes called a track bar in circle track. That is what controls the housing sway in those cars.
  2. 83-88T-Bird Guy
    83-88T-Bird Guy forum member
    200
    Jan 12, 2011
    Bardstown, KY
    Cool build !
    Love the pics and different approaches to achieve the end result.
    I plan to buy a Mod6 ignition setup to fire the plugs on my 3valve when I go to a SDS fuel injection setup
  3. spyder7724
    845
    Apr 21, 2007
    Maryland
    Works good but unfortunately MSD decided not to give the MOD6 individual cylinder timing...other than that it's fine.
    Love the red S197 .... Reminds me of somebody that had one bad ass N/A 3V back in the day.....:whistle1:
  4. spyder7724
    845
    Apr 21, 2007
    Maryland
    Finally got to test this thing out today.
    Losing boost at 800-900ft. and pretty soft on timing. My BOV is opening and dumping all boost. Still got a number of decent shakedown passes. Even blew off the discharge tube on my carb hat the last run. Gonna run good when that stupid crap is ironed out.
    Best ET 1/4mile 9.49 (shutdown at 900ft.)
    Best ET. 1/8 mile 6.06
    Best MPH 142 (shutdown at 1,000ft?)
    Best 60' 1.39 (launching at 4600rpm 7psi 1.48 low gear TH400 two-speed)
    Just a bone stock junkyard truck coyote with no VCT and a carburetor...and boost of course.
  5. jsimmonstx
    jsimmonstx forum member
    584
    May 11, 2012
    Comal County, TX
    You really need to make an intake that accepts a 671 blower... :)
  6. spyder7724
    845
    Apr 21, 2007
    Maryland
    Not that hard if someone already makes one for a navi 5.4 hmmmm....or just adapt one to a roush/whipple lower.
  7. spyder7724
    845
    Apr 21, 2007
    Maryland
    So far making 800-1,000 ft passes it's run 9.34 at a slowing 142mph (1/8 mile was 5.99 @ 121) ....not too bad for something that wasn't supposed to even start or run.
    I'm having some over boosting issues so I bought two 50mm wastegates and in the process of reworking my hot side to accept those. I'm pretty sure once I cure that issue and can run flat out the full run it'll run well into the 8sec range at probably 155mph+
  8. stkjock
    stkjock ---- Madmin ---- Staff Member
    36,363
    236
    Jul 10, 2007
    nice! keep it going.
Share This Page
