Yesterday my 06 GT started chiming when I opened the drivers door (Key OUT of the ignition) I worked the key in and out of the ignition a couple of times and it stopped. Now I have no such luck. Any time the Drivers door is open, it chimes without the key being inserted.
Can't use power locks with the door open because it thinks the key is still present - it unlocks the door.
I have searched and found info on sn95's having this issue but not s197's.
Any thoughts? I took the column apart and everything seems to be connected correctly.
Thanks in advance!
Thanks in advance!
