Yes you will need a dashkit wire harness and antenna adapter the metra part numbers are
Dash kit 95-5812
harness 70-5521 you will need a 1000 ohm resistor for the amp turn on wire or a 5 volt regulator
antenna adapter 40-cr10
Thats the parts you will need to get it done.
