So, My car has been passing emissions with no problems up till now. Local emissions are OBD readings only, no tailpipe or visual: The only changes I have made since the last time it passed are:
A) Replaced the Alternator and the battery about a month ago
B) Eliminated the pipe that recycled the blowoff from the turbo so it now vents to Atmo
C) Installed breathers due to excessive blow by
D) Things I did but cant imagine them effecting emissions, changed out the headlights, added bigger tires, went from 4:10's to 3:27's
Before the test I drove around in stop and go traffic for about 20 minutes. Is it possible that the system didn't warm up enough? I dont have any check engine lights, have not thrown any codes recently.
The specific reason listed for failing was FAIL- Due to the all OBD readiness monitors not being supported
One odd thing I noticed that I have not resolved, and I dont know if it has any bearing on the issue, in my old tune I was able to change the tire size or rear gearing by reloading the tune and adjusting the parameters. This one I cant, is the new tune simply so locked down the OBD scanner at the emission center cant read what it needs too?
Yes I have searched, googled, called and been confused as hell by multiple conflicting answers. Any input, suggestions appreciated
