Fail Safe Mode
05mingreygt
Anyone's car ever go into fail safe mode? Happened to mine a day after I washed my motor. So I think that's the problem. Thinking it might be the TPS sensor so I'm going to try changing that. Any other thoughts on what it could be? Or is it a list of things it could be? Any help is greatly appreciated.
05mingreygt
I usually do. But it messed up half way through. So I had to switch to a reqular water nozzle and just tried to be carefull with it.
amustangrocks
rockaway beach missouri
most often that problem is the tps, not sure if water on the connector would cause that, but i guess it might. ive washed mine a few times over the years, never had any issues. we had a tps go bad and throw the fail safe. its cheap plastic inside that fits onto the butterfly shaft and the plastic gets wallowed out. the replacement has a metal clip inside thats a much better idea.
ive also had failsafe when my tb motor got jammed, but it also wouldnt run at all. it would start, just not drive.
