Ask Jason at Department of Boost. Not sure if one exists but if it does then Jason will know about it.
I read like 4 pages and didnt see this mentioned other then you replying that you dont go boost on stock internals in overdrive or 5th gear.
Ive always been told you absolutely do not go wot full boost in 5th or overdrive even with a forged engine if you want it to hold together. Its extremely hard on it
So today I'm working on bearings for the rods and mains...
Quick question: Ford calls it "Main Bearing Journal-to-Cylinder Block Clearance" and I'm looking for "distance between crankshaft journal and main bearing"
Are these the same thing? I find that the manual has weird ways of describing specs.
For the 3v 4.6L, this spec is 0.0009-0.0019" and for the 03 Cobra 4.6L lists as .0009-.00216"
Since the Cobra is supercharged, too, I'm inclined to use those specs. I'm also inclined to stick closer to the "tight" side of that.
Can anyone lend any sources showing why I might not want to do that? Or am I on track?
Thanks!
BP
All you can really do is measure and record. All of your machining is done, correct? Some people will do half shells of .001" difference bearings to fine tune the clearance by .0005".
I'm inclined to believe that as the machinery gets better so do the tolerances. Since you have a 3v I'd stick with 3v clearances if possible. It could be different crank materials expanding differently when at operating temp, a hotter operating temp, different bearing materials, lots of things.
As long as they are between .001 and .002 you are good imo. Did you have the machine shop target any particular size when they ground the crank or did the line bore?
