Ford Racing 5.0 forged Aluminator crate engines!!!
JimIII@JDM
Just got an email from Wayne Geoffrey of Ford Racing and he notified us that Ford racing has released a forged 5.0 crate engine that comes fully assembled oil pan to intake manifold! (intake cover optional) This is a version of the factory engine with forged rods and pistons with lowered compression. Its comes fully timed, assembled, and covered! The engine is dubbed the Aluminator 5.0L 4V and is going to be offered in two versions 9.5:1 compression for supercharged engines and 11:1 for stock compression or NA builds. The 9.5:1 motors are in stock and available through JDM Engineering!! Contact us for any more at 732-780-0770 or email [email protected]
M-6007-A50SC 5.0L 4V DOHC ALUMINATOR 9.5:1 CRATE ENGINE- SUPERCHARGER READY -
Now in Stock!
Ford Racing's 5.0L Mustang "Aluminator" crate engine is a modern 5.0L 32-valve DOHC V-8 that uses advanced features like Twin Independent Variable Camshaft Timing (Ti-VCT) to deliver big power.
Unlike the factory 5.0L engine, the "Aluminator" is built with low compression forged pistons and H-beam connecting rods to meet the demands of forced
induction.
Fits 2011-2012 Mustang
5.0L 302 Cubic inches
9.5:1 Low compression ratio (nominal)
Mahle hard anodized forged pistons with Graphal low friction coating
Manley H beam connecting rods w/ ARP bolts
Boss 302 Valve springs Part # M-6513-M50BR provides higher seat pressure for supercharged applications
Large sump oil pan, 8 qt capacity
Composite intake manifold and 80mm throttle body
Comes with manual tranmission engine harness and flywheel
Vehicle harness and PCM not included
Machined front cover for FRPP Whipple/Roush supercharger belt drive
Ford Racing 0 degree spark plugs for supercharged applications
Ford Racing oil filter
Remote oil filter adapter included
Tuning required for optimum performance
r.barn
Pssst. I think there is a vendor product release section now.
Ford on the ball again though :beer:
JimIII@JDM
Damn your right! now im gonna be that guy with "Moved" next to his thread...:newbie:
94tbird
4R70W FTMFW
NY/NJ
what oil pump? it better have forged oil pump gears
it's not even on FRPP website yet. The boss motor MSRP is 12K
JimIII@JDM
$7500 is our price to the public
Retail is $8099
Jobber $7699
IN STOCK!!!
KungFuHamster
Ft Worth
i see that the cover is machined for whipple/roush blower use already.
so does that mean someone can order that cover seperately and just swap them when doing a whipple/roush blower vs grinding their stock shit?
19COBRA93
Ford Racing
Clinton, Ut
Considering the risk of oil leaks after replacing a timing cover, I'd bet it would be easier/more desirable to just grind whatever needs to be ground on the original cover.
KJGT
East, TN
+1
Once you have the grinder in your hand and everything moved out of the way grinding the cover for the Roush/FRPP is not hard at all - just a little messy. You can always buy a stock cover and replace the ground down one if you pull the blower..
Be pretty cool if they sold them less covers and manifolds, I already have a stock intake/TB/rails/injectors I dont know what to do with :)
ZmanM3
The Evil One
Jackson, NJ
I'm buying a lottery ticket while I'm on R&R and I'm going to use my winnings to buy one of these engines!
06whipple
Guest
Ford should let you order your new mustang with this engine already in it.
