AutoXRacer
Hey guys,
Anyone install Fore Innovations fuel rails on a ROUSH supercharged motor; M90, VMP 1.9L TVS, or the 2.3L TVS?
The alternator is bolted in three places, two ears and one rear mount, but using the Fore Innovations fuel rails does not allow for the L shape bracket to be installed. So the alternator would only be held by two bolts. Not sure I feel comfortable with that.
As you can see from the picture below, the L shaped bracket just barely fits between the fuel rail and the alternator...
These are the only two bolts that would support the alternator.
I do not know how long those bolts would keep tension while banging through gears on a road course.
Here is the LH (driver side) rail overview:
I bought a complete kit in hopes to replace factory rails, lines, and filter.
This kit plugs into the factory line coming into the factory filter and then you just route the new hose from the new filter to the engine bay, to a y block, and then to each rail.
Any help would be greatly appreciated!!
