BruceH
BBB Big Bore Boss 322
Selling a short block I put together a few months ago. Price is $2800 shipped CONUS.
Parts list includes a WAP 1L aluminum block from a Mach 1. It's bored .010" over.
Pistons are Wiseco skirt coated with -6cc of relief. The relief pattern allows use with a 2v, 3v, or 4v head. With a 3v head compression is 10.2.
Stock 4.6 3v crank from my stock motor. Rods are new Boss. Bearings are King main and Sealed power rod. They use the AL-5 material which is close to stock.
Rings are Wiseco.
Specs are .0016" to .0019" for the bearings, .003 for piston to bore, side rod clearance of .010" to .011", end play of .012". The torque to turn the installed crank only was 20 inch pounds. Rings are gapped at .017" and .020".
Hone was done with a Rottler Diamond Hone to stock specs.
Areas of concern are scratches on the oil pan area, I'd add a thin layer of RTV between the block and oil pan gasket. There are also some very small scratches on the deck. They were noticed after the block was brought home and assembled. I'd use copper spray rtv on the decks and call it good but the proper way to do it is to have it decked. The price reflects this.
