Oh, I would look if maybe a hose got damaged during install at least.
Sent from my Nexus 7 using Tapatalk 2
I think I'll pull the hat tomorrow and check everything.
So if under wot the 02 sensors aren't taken into consideration its in the tune? is there a way to test an 02 sensor? I dont remember them being exactly a cheap part.
I trimmed the hose about .25 to .5 of an inch and replaced everything. Took it for a drive today and its worse. I was watching the screen the whole time to make sure I didn't max out the pump but today it was erratic.
I got 100% dc while maintaining a constant 3500 rpm. It held delta psi until 62% dc then dropped to 28 psi before building back up around 35 psi. Then at 94% dc it drops down to 17 psi. It hits 100% at 3491 rpm (NOT WOT) and drops to 11 psi, 6, then 4 psi. ALL AT 3500 +/- 50 RPM!!!!!
at 100% dc the volts are 13.10.
Im about sick of this shit.
Whats next boys? GT500 pumps? Going back to stock? Blowing a motor? ughh.....
I was looking at boost a pump, but it seems to make the pump work harder by giving it more voltage. If my pump is 100% dc at 13 - 15 volts how does adding more help?
Who's tune are you running? Lito's, or are someone else's and he is helping look at logs?
It almost sounds like to me that the fuel pump voltage tables and other tables associated with the return fuel system aren't calibrated for the pump you are running. It can result in incorrect fuel pump duty cycle calculations, erratic fuel pressures as the computer tries to learn on the go. You'll see erratic and and rapid swings in fuel pressure as the system tries to anticipate where it needs to go to stablize your DeltaV @39psi or whatever is being commanded by your tune.
It has been several years since I did any SCT tuning, and I don't pretend to be anything other than an amateur enthusiast who had the opportunity to learn a bit and apply that to tuning my own car, which I stopped once I got into more than basic bolt on's.
compare fuel pump volts to actual fuel pump volts and see if they are close to matching, the pump will start out at the volts in the table and then correct its self...the closer they are to being correct the faster or less correction needed....for the problems you are having thou, the tables would have to be really out of whack to be that bad IMO......sound slike a physical issue
BAP wont do anything for you.
have you tried blowing out the fuel lines? you said something ruptured...exactly what was it and how did you fix it?
Think it could be the wire upgrade?
Let me know what they find out!
Never had it dyno'd. I will be at the Pro Dyno meet next weekend. And mine is reading maxed out at 5800 rpm but the Air fuels dont change like you would think and it definitely makes it to 6000 without fallin on its face.
