W3bb3r04
Slow 3v Member
Im on 9 lbs it should be close to 480
Any updates?
The line going from the pump to the hat burst. It was really only a rip and there wouldn't be much debris if any and the filter would have caught it, which I replaced.
I just logged it again with the re-loaded tun and it didnt feel erratic but it did not feel 100%.
@ 100% dc
FPUMP_ACT_VOLTS 13.65
FPUMP_FLOW_RATE 1.48
FPUMP_VOLTS_TAB 8.02
I have seen the fuel pump act volts @ 14.53 and volts tab @ 9.78
IMO there is a restriction in the line. Something is stuck somewhere between the hat and filter most likely. It would be a good reason to upgrade the line.
I had this thought as well at one point. Maybe when he had the fuel line rupture a piece of hose or fiber that reinforces it made its way into the line or hat somewhere and it stuck before the filter. Its a longshot but we have tried alot of stuff so far....
Let me know if you guys can tell anything from this?
No its the same set up as Zquez. Walboro 405 with the wire upgrade
Why is it so rich? Is that by design? I'm seeing under .75 lambda, that's under 11:1.
You think this could be the cause of the pump maxing out?
