im having gear whine with my 3.55's on my 13gt. would changing from a 1 piece aluminum to a CF DS help any?
Seriously? If you have gear whine the gears are the culprit...anything else is a band aid fix. They have lots of passes on them?
Ya seriously, the car has had the gears changed twice by ford, no luck. I'm thinking of buying 3.31's and having a shop do it. Just curious of other options.
Ya thats why ford has all the sloppy rubber everywhere and the lead shot in panhard bar and anxle weights on to reduce gear whine. And we all firm every thing up and bitch about the noise more gear is worst in my experience thats why i like my .331 and rousch upper for lowered cars it pretty quiet ds wont help probably worse
Yeah I hear quite a bit more noise now (road noise/whir/popping/clunking) after going to spherical bearings in my control arms and a aluminum driveshaft. Not real happy about it but it was expected.
Going to an offroad H and resonator delete also had some unintended and unhappy consequences as well.
Darn mods. lol
Keep taking it back to Ford. They owe you a relatively noise free rear end. It could be that something is wrong with the housing or tubes and the resulting geometry is causing the noise. If that's the case then no gear installer will be able to give you noise free gears.
It sounds good outside the car. Inside I just don't like the metallic rasp. I keep waffling on getting resonators welded back in to help take the edge off it.
