Help relocating the iat. Any how to's?
beefcake
Forced Induction Specialist
Bethel, Ohio
Im assuming ill need maybe a lightning sensor and connector or a 2 wire sensor of some sort?
Anyone have any recommendations? also which wire(s would need.to be pulled from the maf?
1lowtoy
Here is a PDF file for the MAF harness.
  • 2011 MAF pigtail.pdf
beefcake
Bethel, Ohio
For the record, the part #'s are
IAT sensor F57Z-12A697-A
Pigtail/connector kit 3U2Z-14S411-JZA
1lowtoy
If you are going to put this in a pressurized pipe then you should use the threaded sensor, part number F6SZ-12A697-A.
1lowtoy
That is the downstream IAT (IAT2) sensor for the Ford Lightning. That other sensor is the IAT1 (upstream) sensor for the Lightning, as well as a few other Fords. The older IAT2 sensor was in a metal base and the new version is in a plastic base. I normally weld in a bung to thread the sensors into, if they are going into a pipe or tube. I would be worried about blowing out the sensor if it was just in a grommet.
ILW84U
Edmonton, Alberta
I have mine on in a grommet & there is no way that SOB is going to come out. I will probably break it to get it out if it ever needs to be replaced.
beefcake
Bethel, Ohio
part numbers for the screw in and plug
3U2Z-14S411-JUA
9C1Z-12A697-B
kyoshosp2
Baton Rouge, LA
nope mine is blow thru.. mass is 12" away from the TB. i need to spray meth infront the TB so i need it to pick up the temp reading before the TB also , can't spray it befor the meter that would fuk things up i don't think they like water in them... Beefs should be the same as mine.
beefcake
Bethel, Ohio
for the record.
The purple wire gets disconnected completely from the MAF and goes to one end of the IAT.
The blue wire gets split, we used a connector that crops into the wire and ran it to the other end of the iat.
That way you get the signal you need for the maf, and for the iat.
