Lupo222
I posted this a month ago or so on another forum, but wanted to get some input from here.
I just recently installed a Saleen S/C on my 06 GT. I have Hot Rod cams and Long Tube headers...
After the install with the stock 4" pulley, i wasnt making any boost at all. Checked all the vacuum lines and everythings good. 18-21" of vacuum at idle in gear. Checked out with most other guys.
BBR and Brenspeed both told me they think it is the Hot Rod cams. They said their too aggressive on the exhaust side for such a small amount of boost. As they recommended, I bought the 3.4" pulle and KB BAP and now I'm seeing a solid 2.5 to 3 psi of boost with around 5psi above 5.5k rpms.
Anyone else ever have this problem?? I'm thinking about buying the Detroit Rockers FI cams if it is infact the hot rods that are causing this...
