Innovate MTX-L wideband won't power on
0517suhleen
I did the search. got myself this far, and I am no PHD degree holding electrician but what's going on here? I tried all the switch on fuse slots in the SJB. I double checked all my wire to wire connections.
POWER
GROUNDS
wabirch
Bill
Illinois
Is this coming from a 10a slot, not the empty slot in between the 5a? I think the 10a and 5a are hot all the time slots.
I'd clear any paint on ground points too.
Wes06
not 100% if it would be it. But the Add-a-fuses I put in, I have them facing the opposite way
0517suhleen
I have tried all these fuse slots, they should be switched fuses
dv8uagain
Worthless
Philadelphia, Pa.
I'm happy I am not the only one that went through this situation. I had to flip mine as well. Guess it didn't make good contact.
07 Boss
Sin City
Does it power up when you wire it up direct? If not, it's your grounds or a bad gauge.
AutoXRacer
I would only use the fuse box for a signal... The gauge should be wired with a relay and getting its 12V source directly from the battery.
Do you get an error code that flashes quickly during the heat up cycle?
