Digital_Synapse
wow
PST is who we use for our driveshafts. We have used them for the last 7-8 years.
They will take care of you, and you will not be let down with what they offer.
Calvin, I hope you get this resolved.
I shipped my Shaftmaster driveshaft back today. Im going to go with the PST driveshaft, I talked to them today. I have to take a measurement then going to get it ordered up.
Kelly, can u pm me a price on the BMR driveshaft safety loop. Thanks
Im going with the Aluminum one. The CF one is big money.Aluminum or CF?
Not sure I buy this....
I personally feel it has more to do with the slip yoke design vs. a CV joint design.
Pinion angle is the key and may be beneficial to set it properly for this piece to work as intended.
Im not trying to sell it, but it is basic engineering math.
Low critcal speeds are cause by a combination of the following:
Length of tube, the longer the lower the c.s.
Diameter of tube, The smaller dia the lower the c.s.
Weight of material, The heavier the the lower the c.s
Tube wall thickness, The thinner the lower the c.s.
I agree that pinion angle is a factor but its not the exact cause. you'll likely not run into a driveline angle issue with a mostly stock arrangement car.
Now as far as the slip yoke goes, We use a spicer brand slip yoke. These slip yokes are similar to what is found on hundreds of thousands of production vehicles across the country. Assuming that they are using the same slip yoke as our 05-09 shaft I will have to say that it is not the slip yoke.
Bottom line is 3.5" is fine. D/S diameter is not the issue here...
It could be, especially with an aluminum shaft.
lot of factors involved, I kind of look at it this way though. If Ford could have figured out how to do it with a simpler and CHEAPER one piece driveshaft with no NVH issues, and they have some pretty good engineers, then it would have been done from the factory.
Has anyone broke a stock 2011 GT driveshaft yet? Just curious.
You bet. The tend to fail at the CV joint and then candy cane.
Attached are pics of one off a low 12 sec. car.
Hmm, I havent seen a 2011 break myself yet. I assume it was a stick shift car.
I seen the 2011 V6 one on the dyno explosion thread but the V6 has a different driveshaft.
I have gone 10.80s on the stocker and have no plans on changing it again after dealing with the first one piece I bought. If I was racing the car every weekend I might but i doubt I'll hit the track more than a couple times a year. I drive the car every day so no vibration is more important to me right now. I know someone makes an aftermarket 2 piece for the GT500s, not sure for the GTs, but its pricy.
I have seen a lot of stock GT500s at the track getting beat up and I never seen a driveshaft fail so I assumed they were fairly strong. Granted they are heavy and the center bearing is just another thing to eat up power..
Yes was a stick car and for sure have more driveline shock than an auto.
I will be installing my D/S in the near future and will post if I experience any issues. I think the Shaftmaster piece is the best 1 piece alum. design on the market. If something is wrong after install I will have them send me a replacement.
