COYO TT
Stangless
Ive had my shaftmasters up to 130-140mph and is like a dream
They got back to me with what was wrong with it. They installed it on their balancer and checked the runnout and balance. Their not quite sure how it happened but the runnout at the trans. end was excessive causing an imbalance issue even at low rpm's which is very unusual. These things happen, there customer service is excellant.
my shaftmasters one. Im rocking the stock one nowAre you referring to your shaftmaster DS or your new one?
I have a minor vib starting at 90+. It is minor but noticeable, shaftmaster as well. put in a Adj UCA and it helped a little.
I'm in Germany so getting it balanced right now is out of the question. I'll have to wait until I get back in the states this summer. Of course I won't be able to drive it at 100 mph legally anymore
I got my PST drive shaft today. I'll get pictures soon the thing is amazingly light. With only a universal joint at one end and CV joint at the other it does away with the huge heavy sloppy sliding joint. Very cool.
....and the Shaftmasters uses no adapter plates. What is the point of this post?A true one piece drive shaft. No slip joint or adapter plate.
Right so the PST shaft has a CV joint which by its very design has some length change and an universal or carden joint. Other driveshafts have two carden joints and a slip joint which if there is any slop in in it causes the whole shaft to wobble causing vibration. Plus universal joints are very sensitive to alignment. CV joints don't have that problem they don't need to be aligned as they are constant velocity joints by virtue of their design. Look I don't sell driveshafts you want to buy 100 year old technology and read almost every day about vibration issues fine with me.
Two things to check:
1. Did they align it with the marks on the rearend flange and the driveshaft? There should be a line on the driveshaft that will align with a mark on the rear end flange.
2. Where is the slip joint? If it is at the transmission, turn it around and put the slip joint at the rear end.
You can also opt for sending it back and getting one from Dynotech. I installed one not long ago and it is as smooth as a baby's ass. The slip joint on mine is at the rear end too.
HTH
Mike
