It's Happened Twice Now....
07 Boss
Sin City
A week or so back my car overheated as I pulled into my driveway. Water pump is pumping, fan is going. Weird shit. I cooled her back down and added water to the system and then could not duplicate it. Idled in the driveway for 30 min. with ac on. Turned ac off and ran a high idle for about two minutes to even get the temp up to normal. Been driving her daily all week 100*+ days with no issues. Happened again yesterday sitting at a light. Managed to get it into the gas station on the corner and shut the motor. Once she stopped spewing coolant I ran the pump and added water and cooled her back down in a couple of minutes. Sat there with the car running, nothing out of the ordinary.
First thought is the thermostat which I will pull today or tomorrow but it strikes me as weird is you wouldn't think it would be this intermittent of an issue if the thermostat was sticking, no? Or can it just shut randomly? I mean car was up to temp and been driving about 20 minutes before she got hot.
TylerM
Edit:
Is the original radiator in the car?
Sent from my SM-G960U using Tapatalk
MrBhp
Mine was doing that. Turned out to be the "overheating in the fuse box" problem. Fan would only work properly when I was staring at it. Would run slow or not at all when I would turn my back. I tricked it with an elaborate mirror setup. I moved the relay, fuse, and feed wiring outside the fuse box.
DieHarder
MrBhp - Senior citizens, although slow and dangerous behind the wheel, can still serve a purpose... Targets - DeathRace 2000
TylerM
Yes it's the original radiator. Cooling system gets flushed every other year.
Ok. I had a similar issue, the only thing that cured mine was replacing the radiator. I upgraded the water pump and radiator fan at the same time.
bl817
MrBhp, do you have a write up with photos on how you did that? I have a thread bookmarked from a while ago and all the pics are gone
MrBhp
I will see what I can find. Car is currently not at home. F'n transport.
bmeaggie
Haslet, TX
I had this exact problem earlier this year. I tried every recommendation that I could find. I was changing coolant, squeezing tubing trying to get bubbles out. The problem started very intermittent and slowly became more frequent. I finally got the overheating to happen when I could pull over immediately and when I did the fan was stopped. Now of course everyone told me that fan failures were very rare, and that it must have been something else. I had a GT500 fan that was only 4 years old after all. The fan relays were crazy hot... melting when the failure would occur. Now people were telling me it was the fuse box, as if fuse boxes without extreme age or corrosion just “go bad.” I ordered a new GT500 fan from Summit, installed it and problem gone, and has stayed gone. The fan was drawing too much current, overheating the fuses and causing the system to shut down.
07 Boss
Sin City
Interesting, I have a manual switch for my fan and pump that I can use if I need to but will look into the fuse box heat issue. I started the car this morning with no ac and drove all the way to work stopping for smokes. Got to work and the car was at it's normal temp but the fan wasn't on. I just now went to the store and back and started the car with the ac and the fan was running the whole time. I haven't been to the track in a while so I will have to put a new fuse in that circuit since I wasn't using it.
How did you track or diagnose this fuse box issue? Everything seems to be OK when I look at it.
07 Boss
Sin City
Well I'm not going to throw a bunch of parts at her and hope. The pump is new, the radiator is clean and flowing, and the fan works. I'm leaning to something electrical or ecu related.
07 Boss
Sin City
I had this exact problem earlier this year. I tried every recommendation that I could find. I was changing coolant, squeezing tubing trying to get bubbles out. The problem started very intermittent and slowly became more frequent. I finally got the overheating to happen when I could pull over immediately and when I did the fan was stopped. Now of course everyone told me that fan failures were very rare, and that it must have been something else. I had a GT500 fan that was only 4 years old after all. The fan fuses were crazy hot... melting when the failure would occur. Now people were telling me it was the fuse box, as if fuse boxes without extreme age or corrosion just “go bad.” I ordered a new GT500 fan from Summit, installed it and problem gone, and has stayed gone. The fan was drawing too much current, overheating the fuses and causing the system to shut down.
I'm going to look into this a bit more. I think I will wire an LED into the ground side of the fan motor so I can see when it turns on and off. At least then I can monitor it real time.
You need to figure out if overheats and pushes coolant out
OR
You have a small coolant leak that causes the car to overheat because the coolant got low.
bmeaggie
Haslet, TX
Some more important points:
I eventually realized that my fan would usually stop working on the second leg of my errand... meaning I would take one of my 10,000 children to soccer or something, and everything would be fine on the way there. Then, on the way home the AC would start blowing hot air and the temp would suddenly start climbing. It would climb fast too.
I think the fan motor was dying, drawing too much from the relays, and the relays would eventually overheat/expand/whatever and stop working. Then the fan couldn’t turn on anymore, but after cooling down the relays would work again.
So... key things with my failure mode were 1) car had to heat up first... would never happen on cold startup 2) AC would start blowing warm air 3) the fan relays would be crazy hot to the touch when fan wasn’t coming on.
Good luck! Curious what your root-cause turns out to be. Let us know and how you fixed it please!
07 Boss
Sin City
Well from what it looks like is the fan runs all the time when the ac is on as expected. It's when I turn the ac off does it seem to have issues. The signal to the fan goes through the same relay whether its the ecu or the ac telling it to go on right? I haven't pulled the fuse box apart yet but I will at least throw the horn relay in the fan relay spot and see if the thing comes on.
Ecu turns on the fan. For AC or for coolant temp.
bmeaggie
Haslet, TX
So to make sure... have you overheated the car, opened the hood without shutting off the engine, and made sure you can still activate the fan by turning on the AC?
If “yes” to that for certain... There are TWO fan relays... a high speed and a low speed (1 & 2). I think the high speed = ac activated. Maybe your low speed relay is bad?
Good point about the 2 relays.
