Jack stands under an S197
Synyster06Gates
Leander, TX
Going to be working in limited space this weekend due to rain - so I was wondering where the best place to put a jack stand would be. I will be doing axlebacks, so the back end of the car needs to come up - whether it's one side at a time or the whole thing.
I'm using a 2.5 ton floor jack with a flat pad and have a pinch weld tool so I can jack it up in the factory spots with no issue. I'm hesitant on jacking up from the pumpkin because I would be the unlucky one that ends up damaging something.
Looking at this photo, they recommend a jack stand on the rail with the red dot on it. The front wheels of my jack make this impossible. Can I place the stand on the rail closest to the rocker panel or will it collapse under the pressure?
Can I place a jack stand under one side of the axle at a time or will that damage the tube?
JUSTA3V
Moar Throttle!
Queen Creek AZ
I go 2 inches back from that red dot where the metal is doubled up. Right in front of the LCA connection point.
I never put stands on my pinch welds ( what you are pointing at)
I have supported the car on the axle tubes as well before without issue.
Synyster06Gates
Leander, TX
I tried a few minutes ago and didn't have enough room to get the stand under the area you're talking about with my jack holding the car up. Also - I know I can support the rear axle with two jack stands no problem - but if I am only able to get one side up at a time, I would be hesitant to put pressure on only that one side.
I am jacking from the pinch weld with one of these
JUSTA3V
Moar Throttle!
Queen Creek AZ
Jack it up on the pumpkin? Or do you not have a floor jack? Are you using the stock scissor jack?
Synyster06Gates
Leander, TX
Using a floor jack - but I've heard bad things about using teh pumpkin.
I could go pick up a rubber hockey puck and do it that way though, it would just about ensure I don't fuck it up
JUSTA3V
Moar Throttle!
Queen Creek AZ
I have always jacked up my car on my pumpkin. Since day one. Just have to make sure it's centered and not on the cover.
Phil1098
Central Illinois
Why not just back it up onto some ramps? If you don't have them I would get some if for no other reason than oil changes.
skwerl
tree hugger
central Florida
This. Use a short chunk of 2x4 as a jacking block if your jack pad is going to hit your pumpkin cover. Sounds like you are way overthinking this entire procedure.
Synyster06Gates
Leander, TX
Probably - but I don't want to fuck anything up and I don't want to get crushed
5tangiac.0
Houston, TX
Not to high jack the thread but do you know of any decently priced ramps that I won't have clearance issues with in the front?
Mach2burnout
05 Redfire GT
Central Louisiana
If your lowered and have a front spoiler or splitter them I think the only options are to make some out of some 2x10 or 2x12s or "race ramps" which are pricey imo. I made some 2x12 ramps 2 boards high and place them in front of my auto zone ramps to get the front end up a little. Works perfect and I use these same to get my jack under the car.
Sent from iPhone
5tangiac.0
Houston, TX
Good info. Yeah the race ramps look awesome but they are pricey. Anyone try the harbor freight ramps?
JEWC_Motorsports
S197 Junkie
Texas
I use rhino ramps, they are around 50 bucks. Im lowered on 2013 cj springs.
Riptide
Will work for Mustang.
Montucky
Does a supercharger really drop the front end that much? I have 27" tires up front, barely shorter than stock, and my car won't go up rhino ramps without rubbing. I can't even get a floor jack under there any more. The car doesn't look much lower to the eye so it's always kind of puzzled me.
Not much of a problem now that I have the race ramps though.
And yeah just lift the rear end by the differential.
Phil1098
Central Illinois
Here is what I did to my Rhino ramps, made a huge difference.
