I installed a JBA axle back. Sounds great easy to install and happy with the product but there is one problem....the right tip sticks out a bit farther then the left. It appears designed to stick out enough for the JBA logo to show but the right side is that plus a half inch which is driving me nuts. My buddies say there is no problem and it looks fine but its a bit different when you own it. Anyone have this problem with an axle back? I'm thinking I should be able to adjust it if I loosen the bolts at the h pipe and play with it but I wanted to ask before I climb under there for nothing. Thanks
