Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 28
Alrighty kids. As you may know I offed my 2007 street/track/mile car. My interests have gotten back to my roots (track time) and the car was a horrible tool for the job. Too heavy, too complicated, too much power, etc. I could have done a huge conversion on it into a dedicated track car, but that would have been more work than just starting from scratch. Not to mention for a track car I wanted a Coyote motor. I was really ready for a GT350R. But after I weighed all the pros and cons it really just didn’t make sense. Just so ends up that I have a 2012 GT Brembo Vert with only 30K miles on it. Let the fun begin!!!
So here is what I want to do. This car will be 80% track/20% street. So it can be harsh and extreme. Right now it’s near stock, so that makes it easy. It needs EVERYTHING. The car needs to be a “Track Day Killer”. I really don’t care about street “drivability”. Things like rod ends on the suspension and high rate springs don’t scare me in the least. It’s going to be all about suspension, reliability, simplicity and safety. And the simple parts needs to directly translate into “easily serviceable” and durable. I’m not looking at working on it all the time. Show up, drive, go home.
I don’t have a huge budget, but since I’m no longer looking at a GT350R I have a decent budget to play with. What I want help with from you guys is in refining the “to do” list. There is likely to be things I forgot, maybe got wrong, etc. Your suggestions would be great.
Here is the list of stuff I’ve already pretty much decided on. I’m going with Cortex stuff, that’s set in stone. The stuff in blue with question marks after it (????) is stuff I need more information on and they are re-listed last in a section for “What do I do about these?”.
Suspension/Wheels Tires:
-Cortex Watts Link
-JRi double adjustable struts
-JRi double adjustable shocks
-Bump steer kit
-Cortex torque arm
-Cortex K-member & Front control arms
-Cortex Xtreme-Grip Rear LCA’s
-Some sort of adjustable swaybars (TBD)
-Cortex swaybar end links
-Enkei PF01’s 18x10.5 at all corners
-Nitto Nt01’s 305’s at all corners
-Long ARP wheels studs front (I already have them)
-Long ARP wheels studs rear
-Re-program steering rack to Ford Racing specs
Brakes:
-Stoptech ST-40 Full Floater big break kit (I already have them)
-Brake ducts and backing plates 3” (I already have them)
- GT/CS BOSS lower fascia????
Cooling:
-Afco radiator (I already have this)
-Oil cooler. What is the biggest baldest one I can get in there. I seem to see they run hot????
-Oil line/Block adapter M-6881-M50
-Canton remote mount filter (I already have this)
-Tiger Racing hood
-Rear diff cooler????
-Trans cooler????
-High flow grill? I want to ditch the fog lights so I will need something here. Suggestions????
Engine:
-Petersons crankcase breather tank. The same ones the race cars run. (I already have this)
-FRPP BOSS 302S/R off road mid pipe
-I need some OTA pipes with no resonators and maybe some mufflers (I have the quiet Magnaflows and will probably ditch them. I’m thinking cheap here??????
-Some sort of CAI that is actually a CAI. Maybe a BOSS 302S/R piece????
-Prothane engine mounts
-Tune
Interior/Safety:
-Maximum Motorsports 4pt bar with custom bent “door bars” (ends up being 6pt to tie the chassis together)
-Sparco Fighter Seats (I already have these)
-Crow 5pt harnesses (I already have these)
-Sparco steering wheel (I already have this)
-Do I need arm restraints or something????
-MGW Race Spec shifter
Miscellaneous:
-Tubular bumper support
-Front and rear tow hooks
-Move battery to trunk
-Pedals more conducive to heal/toe. Any suggestions????
What Do I Do About These?:
-Front lower fascia that will accept 3” brake ducts. Will the GT/CS BOSS one work for this????
-Front splitter?????
-Oil cooler. What is the biggest baldest one I can get In there. I seem to see they run hot???
-Tran cooler????
Any things I’m forgetting (I’m sure there are some). Suggestions? Fire away!
Thanks!!
-Cortex Watts Link
-Bump steer kit
-Cortex torque arm
Brakes:
Cooling:
-Tiger Racing hood
-Trans cooler????
Engine:
-Tune
Interior/Safety:
Miscellaneous:
-Tran cooler????
Thanks!!
